Heheheheeh "Truck" + Ian's GTR = loser mobile!!!
My car might not be a GTR, but it works!!!
Just jokes Ian, don't blow a gasket or something! (And I didn't mention Steph at all!!)
I lool'd
yes that's right, LOOL'd
That's right you weiners, talk up your illegal mountain runs on a public forum. Nice work. Hey while we're at it, anyone wanna buy some drugs? I've got a nice little stash happening if anyone wants to pop over. My address is 6/5 Chris....
Haha dave, things have changed since you last saw my GTR up a mountain....
But im not one to tempt fate and dont want to get into any death runs over nebo over a grudge, so ill come out right now and say your probobly quicker then me over a mountain.
softcork, u and me both know even a stock gtr with a 12yr old behind the wheel could beat any mielsy gts-t :)
ud go to jail for longer caus ur the dealer :)
Oh, and I QUIT MY JOB TODAY!
about time bish...wats the plan now? oh and gonna make a scence???
:) whoa, a little touchy there shane
so how is everyone this morning, little hostile from what i can see.
haha not even man, i said that to fire up the gts-t owners, i enjoy watching them fire up :)
Hey whores
Anna as far as I'm aware nothing illegal happens on the mountain runs. I've been on a couple and there's nothing dodgy about them... we could have a police car in the middle of the group and they'd have nothing to book us for. That's why Ian mentioned that he wasn't willing to get into a death run over Nebo to prove it :)
Ian, glad your car is running again :)
softcork, u and me both know even a stock gtr with a 12yr old behind the wheel could beat any mielsy gts-t :(
hahaha, no, coz the gtr would break down before it left the house :)
hi marc :(
Edited by lilmike86
be there in 10 i'll swap you for plasma TV or do you take Credit cards??? :)
:) so its off to uni now dear?
Hey whores
Cheers Marc :(
nonsense. You dont have any drugs. If you did, youd have used them by now.
*chews face*
I didn't know RUNNING gtr's were in existence anymore :)
Says the man who wants to put a 20BTT in a MX5.....
nah, were opting for the 13BTT instead, less weight. and as far as i've seen, mazda are more reliable than a gtr ever will be :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
