Once there was a hillbilly boy who, after getting his G.E.D.(high school equivalency diploma), went to work for his father in the family business of Rust-Collecting.
One day he met a hillbilly girl and they hit it off and started dating. They enjoyed each other's company, and both liked the same things, like Cow-Tipping and Beater-Car-Smashing. Eventually, they decided to marry.
After the ceremony, the boy was really looking forward to the wedding night, and to show how big a deal this marriage was, he took his new bride to an actual,money-paying Motel. When they arrived, his wife went into the bathroom to change, while he was getting ready himself. She came out of the bathroom dressed in her sexiest burlap, and the boy grabbed her and tossed her on the bed. "Be gentle with me," she said,"I'm a virgin."
The boy immediately flew into a rage, got dressed, grabbed the girl and threw her into the back of his pickup truck. He screeched to a stop in front of her parents' house, threw her out, and burned rubber outta there. He drove to his Dad's house and told him the whole story through eyes filled with tears. His Dad comforted him and said,"You did the right thing, son---don't feel bad. A VIRGIN??!! Well, if she wasn't good enough for HER family, she sure isn't good enough for OURS!!!"
So what the news about your car mike...any luck locating it?
nope still no luck. the investigator wants to have it all sorted by next week so hopefully insurance will come through by early feb at latest :laugh: <--thats me hoping really hard
Good and bad i guess...you gonna get another 33 or shop around?
nah, prob get mx5 with a 13btt in it instead, something different
John wants to cyber mike... <3
shhh
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
