Mark... Karen!
we all here demand for this to happen!
Make Slide a sponsor!
we want cheap reliable turbos for once!!!!!!!!
Hi Karen
I am a NSW sponsor at the moment and would like to know if we could provide the same great deals for qld in the member section :no:
yeah im still waiting on my jun bonnet for the onevia
bodykit people are f**king slow
thats why i dont sell them
they are too big and shit happens
lol
want them to take responsibility for there shit product they sent me -
http://www.skylinesaustralia.com/forums/in...t&p=2829543
lol
hahaha
you know everything is imported right?
its like buying stuff from ebay out of singapore which is where these are from lol
Hi Karen
I am a NSW sponsor at the moment and would like to know if we could provide the same great deals for qld in the member section :)
Yeh that would be cool :D
Send a PM to Marc and let him know what you are prepared to offer club members in the way of discounts and/or benefits
He will reply to you shortly thereafter :D He had better anyway or he gets :no:
you get what you pay for :no:
yeah
but doesnt give the business any right to "not give a shit about it"
as you can see now, that will badly reflect back on them.
they aren't willing to do anything about it or come to a comprimisation about any of it.
i asked "well how about i ask how much would it cost to have it properly fitted and we can look at going halves in the cost of this".
he simply said "nahh, im not willing to cause its out of my hands".
what a f**kin lame ass business would say somethin like that to a customer.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
