pfffffffffft u don't hafta be a lesbo to know those girls are crazy hot
Girls know when another girl is sex on legs without being lez :)
she does have a good point :D
Girls know when another girl is sex on legs without being lez :D
Guys also have this ability, we can tell when a girl is hot without being lez too!
yes thats nice and all, but u eluded the quesion :happy:
ok im off this time, bye kids :D
lol
Lesbians are only hot if they are both insanely attractive...
Otherwise keep it to themselves
:D
:) but i always though i was a Lesbian!!!
What do you call a Lesbian with Fat Fingers?
Well Hung!!!
and good moring whorebags :laugh: have you missed me? :)
siiiiiiiif!
Hey Anna, i have this question that keeps nagging at me....
what do you deffin as T Bagging?? just nutts on the for head? i always thought there was 2 types of T baggin...
1.. Guy T bagging - where you get your Balls and place them on the passed out victims head and take Photos!!
2.. T bagging a Chick - Where she lays on her back with her mouth open and you hang your nuts over her mouth and proced to dip them in and out of her mouth.
just curiouse about it when you guys talk about T baggin :happy:
i will do :P might not be family friendly though :O
the second one. i'm pretty sure that the first one is more like the sphincter of the universe slapping someone, just amusing when they wake up ;)
You're an idiot. the sphincter of the universe slapping involves whacking someone's head with the penis.
T bagging involves the lowering of the scrotum onto someone's forehead, and sometimes pushing said balls into the eye socket to form a 'goggle' look.
whats this about?
My driving instructor. He's going to help us get into Mt Cotton's good books so we can actually participate in advanced driver days out there :D
hrmmm
a different anna who likes chick on chick action
:D
Shhhh... don't go spilling my secrets John, you'll taint my good girl reputation :D
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
