so when do u's go out driving?
Pretty much whenever we need to get from one place to another. Oh you didn't mean that... :P
Check the events section (it's under Queensland), if someone is organising something it'll usually end up in there.
MAN I AM SO EFFING PISSED!!!
a cab reversed into my car on sat night outside my house and i know it was a cab cos there is a streak of orange paint on my car, and no one in my street has an orange car...
I just rang yellow cabs, and the guy said unless I can tell him the cab number they're not responsible for it!!
WTF!! it wasn't even my cab it was my neighbours!!!!
I'm gonna stab someone!!!
:P
:P
Damn that sucks... it's ghey how they expect you to do all of the footwork to fix one of their company's mistakes. How do they expect you to get the guys cab # if you didn't actually see it happen? Don't they have logs or something of damage done to their cars? Did one of them come back with a new scratch full of your paint?
I hate taxi drivers with a passion. There are a couple of good ones out there, but unfortunately they are so massively outnumbered by the inconsiderate, oblivious, obnoxious, pig-headed, incompetent, unobservant, useless drivers around them that it's amazing there aren't more crashes or road rage incidents involving taxis. With very few exceptions, they just plain suck.
:P
thats no good,
I used to see you driving into the city most days >_<
very nice.
it`ll come off the wall every now and then... knowing mike
He won't use it for that kind of mounting... he's a sick one :P
:D
stab a cabbie then, thats sorta revenge
anyone got a gun?
>_< just use a knife like most good little emo's
the problem is proving it was one of their cars. there are orange cars around, ex cabs, stuff like that. unless you can prove it, they wont care.
that sucks anna, did you cry?
Yeah I know, it was just a good excuse for a rant on taxi drivers lol
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
