ahh don't worry the hospitals have all started moving to optus :P
well everyone cooparoo nandos at 8??
In whats the adress
yeah tonight why not what does everyone think?
I think its good...I already ate but I am bored
hmmmmmmmmmm interesting....
you're gay
LOL
as if you wouldn't come out!!!
pack later....:laugh:
i'm blowing off my run that i was really excited to go on and looking forward too!
bahaha ur a commedian, i like u :P
In whats the adress
ok i have no clue, but i know what it's near
LOL
do u know coorparoo train station?
anyways, it's in a set of shops off the rd the train station is... what way u coming from?
f**k those directions are so girly bahahahaha
Nando's Coorparoo
154 Cavendish Rd 4151,
(07) 3394 4144
Sick!
LOL
Lolz yes.....yes they are
Eww car sales whore.....
Service Advisor.
I deal with wankers who take touregs up the beach and:
a) wonder why they broke
b) complain about how expensive it is to fix
I can tell you right now, I miss doing property developments. We’ll see how long I last, until I go back to 6 - 7 days a week to play with other peoples money in property.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
