I need spanners but I don't want to drive to get them cause then the damn thing will be to hot to work on Grrrrrrrrrr
Hahaha yeah that sucks hey... catch 22
It's always a good excuse to say "the car's too hot, I'll do it later" :glare:
your an idiot! what the hell? how do you expect to fix your car without spanners?
Order a Pizza and get them to deliver your spanner with it :glare:
I like your style!
I dont have the Correct spanners...It would seem someone has borrowed them!
It's always a good excuse to say "the car's too hot, I'll do it later" :laugh:
hehehe yeh "it's too hot to wax it now" :(
oh, just like someone 'borrowed' our 12mm socket... f**king asses! Everything on a line is 12mm :glare:
MR Benno is coming to the rescue!
oh - benno found me a computer - I think i'm going to buy it today!
I didn't realise wireless broadband was so expensive :laugh: for like when i'm out somewhere using my laptop :glare:
How bad is it?
Dont you just steal other peoples?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
