Hmmm... perhaps we need to ALL motivate each other!
I need a neighbour like ado to message me saying 'get off your ass fattie and go for a run'. Although I have been good these last 2 weeks. Eating better and exercising. All the usual shite you do to try and make yourself feel better :P
Chocolate Mud Cake from the Cheese cake shop makes you fell better :devil:
ha ha ha yes we all need an asshole neigbour who pays out on your physical appearance.. LOL
i swear he gets so much enjoyment out of being able to call me fatty without getting a beaker of acid thrown in his face
:laugh:
your a voilent one.......
but are you all talk?? :devil:
:devil:
lol bridget told me about your nanna, and your photoshopped catwalk model (i think on your fridge) :devil:
I could make my housemate do it...
Nah I would just ignore him :devil:
:P i only said i think we've discussed this before..... lets all post up photo's of our nipples :devil:
This is me being emo EMO NIPPLES - NWS
oh k!
still got the problem with drinking softdrinks though.
Switch to diet my good man! BIG help :laugh:
:devil:
my nan is friggin crazy... she's so cool, i can't wait to get old and senile... it's like being a comedian!!!
yeah i think i have one of my photo's here.. LOL it was before photoshop, so it's only a paint job :laugh:
this is me after I do weights....
it's pretty acurate... LMAO
the other ones are my face on annorexic models that I keep on my fridge to "inspire" me not to eat BAHAHAHAHA
"our" brass knuckles???
u wanna marry me or something?
:huh:
:P
well maybe I have a cyborg arm that will own your plate yo!!!
:devil:
An what if i do???
dam that cyborg arm.... wait let me call Arnie over!! "I'll be Back!"
:laugh:
so who wants to go get a car wash at mt gravatt
Your treat Lee??
but yeah i'll be up for that this arvo....
oh k!
Nice Nipples, but i'm abit wary of those D.I.Y. Breat implant home kits :devil:
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
