...only more expensive, takes up more space, less versitile etc..
my dad has quite an extensive train set so i know what you're about, but i stand by the fact its an old mans hobby
old mans hobby?
lol
there are ppl around the world aged from 10 through to 16 that have a bigger set then i do.
age is nothin to base this type of hobby on. its pure interest in creatin such a thing like this and being able to control and construct somethin thats fun.
old mans hobby?
lol
buy some lego then :thumbsup:
old mans hobby?
lol
rofl direct quote from side of the box huh? :woot:
well each to their own, better than snorting lines of poor quality coke or sniffing lees socks i guess
i'm off to bed, gotta be up at 5:30 :thumbsup: nite all :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
