Full Toss - an involuntary motion best produced behind a bush outside the ground rather than over the lad in front of you
Duck - a quick lowering of the head and shoulders on hearing the opening moves of the Full Toss (see above) behind you
Silly Point - a Kaftan wearer trying to explain the rules of the game to a lad
Leg Slip - a fault in getting up after drinking one’s way through a full match
First Eleven - one short of the first dozen knocked off at the end of the first innings
Extra Cover - raincoat or plastic sheet held above head. (see also Duck and Full Toss above)
Gully - Scottish lad’s word for Sheila
Pitch - apparent movement of the field seen towards the end of the second eleven ( see First Eleven above)
Bail - money required to release lads for the rest of the weekend after being escorted from the field
Wicket - Bad Lad
Extra Fine Leg - bit of a Sheila seen three rows above the lads
Bowler - hat worn by English Kaftan wearers
Forward Short Leg - lavatory talk for relieving ones self
Dismissal - look given by Sheila three rows above (see Extra Fine Leg)
Keeper - advice given to a Kaftan wearer on what he can do with his Sheila
Member’s Stand - reaction to a decent Sheila walking past
A Bye - dozen cans purchased before the game
At first I thought, if I were Superman, a perfect secret identity would be "Clark Kent, Dentist," because you could save money on tooth X-rays. But then I thought, if a patient said, "How's my back tooth?" and you just looked at it with your X-ray vision and said, "Oh it's okay," then the patient would probably say, "Aren't you going to take an X-ray, stupid?" and you'd say, "Aw f**k you, get outta here," and then he probably wouldn't even pay his bill.
Why do people in ship mutinies always ask for "better treatment"? I'd ask for a pinball machine, because with all that rocking back and forth you'd probably be able to get a lot of free games
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
