had to get the ball rolling at some stage
hehehe
only got my car and noy's car left to shoot.
which reminds me i should organise a time with him this wk to do his car
got to wash mine first before i even go anywhere near it with a camera
washing is the pits :rant:
think people would be satisified paying around $28/$29 for a calendar this year?
Should be..it is more detailed than last years
specially in the sun at this time of year
Yep
PS 5 pages in a row Pwned by me
I have this choice....
run a batch of 50 calendars off, each calendar will be $28 or $29 each.
run a batch of 100 calendars off, each calendar will be $25 or $26 each.
since I have to fork up the full amount for the calendars, running 100 of them may see a few of them left in a box not being purchased which i then end up being out of pocket.
can only run these off in batch's of 50.
so, there is the choice of
run the 100 and hope they all get sold
or
run 50 and tell anyone who was to late in ordering them 'tuff luck'
Ask mud how many were sold last year?
Ian......your clutch is buggered, just recently gone through this myself so I know the evil symptoms lol
*waits for the call of shameless plug*
:P
The Perfect Day According to HER:
8:45 Wake up to hugs and kisses
9:00 5 lbs lighter on the scales
9:30 Light breakfast
11:00 Sunbathe
12:30 Lunch with best friend at outdoor cafe
13:45 Shopping
14:30 Bump into boyfriend/husband's ex - notice she's put on 2 stone
15:00 Facial, massage, nap
19:30 Candlelight dinner for two and dancing
22:00 Make love
23:30 Pillow talk in his big strong arms
The Perfect Day According to HIM:
10:00 Wake up
10:02 Oral sex
10:10 Big breakfast
11:30 Drive up coast in Ferrari with gorgeous babe with big hooters
14:15 Enormous lunch
15:15 Oral sex
15:25 Play sports with the guys
16:30 Drink much beer with the guys
18:30 Meet Claudia Schiffer
18:40 Oral sex
18:50 Huge dinner, more beer
23:00 Full on, get down, gorilla sex
23:15 Sleep
i'm not sick but i'm not wellllllllll
and i'm so hiiiiiiiiiiigh
cause i'm in hell!
mike is back!!
and pissed off!!!! stupid pubmole went home sick! now i gotta work till 7! that fat mole! she's apparently pregnant. who in their right mind would do her! you'd have to be blind, no sense of smell, no feeling in ANY part of your body and have no hearing :P
this sucks. i wanna quit :(
cause i'm in hell!
mike is back!!
do it
11:00 Sunbathe
13:45 Shopping
22:00 Make love
10:00 Wake up
10:02 Oral sex
10:10 Big breakfast
15:15 Oral sex
18:40 Oral sex
23:15 Sleep
besides the ferrari and claudia schiffer, that sounds just like high school to me, no kidding :( my ex from back then actually expected those things of me each week :P i still didnt do them :( being male ftw!
do it
no job to go to yet. should prob have a look around.
something giving you the shits mike?
ignorant fat moles that work for me. this is her 3rd sick day in three weeks. i'm just gonna fire her soon, giving me the shits.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
