bahahahaha the fatty's on the biggest loser are crying and passing out
:P
The best part was when that guy fell over
Don't get too excited, I just don't have a better offer as yet :)
*offers* :)
I heart girls that heart boobs.
Indeed...they are the best!
but i'm pretty sure i'm the best big buck hunter this site has to offer
Oh no you didnt girlfriend
ha ha old mate on cops got done for dui, but the cops said to him why were u swerving in and out of traffic? he said well it is a turbo (ford capri) and i just got the accelerator cable fixed, and i put it back to third and it just took off i couldnt stop it, so i had to swerve around traffic etc ha ha so funny!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
