Your house? I can think of a few people who might take offence to that bold and unfounded statement.
I can think of a shit load of people that would take offence to it, but I bet my sweet bitch tits they'd rather me call it my house than you!! ;)
Dude seriously, although I do get the feeling you're part female, you're clearly bored and looking for a fight... I'm going to clarify something for you... No one here cares enough about the internet to really fight, especially with a stooge...
So when u get sick of making a fool of yourself, feel free to push the lil X in the top right hand side of the screen....
*by the way, if you don't know your left from right, right's the hand you use to give reach arounds when your having anal sex with your bf*
Anna, this is the way most fully sick honda driving, tight tshirt wearing poof greeks act, they just need to be cut down to size.
thats not what you told me last night man you said that i was your world and you couldnt live without me. What happened??
HA HA HA
FULLY SICK ULEH!!!!!!!!!!!
roflcopter ;)
Better than Shane. Pick a boys name or a girls name, not both. WTF.
i think he means that there is no such thing as a greek warrior, they all just talk big then run away
hi anna :wub:
Morning! :)
herro anna dear :P
HI ;)
Anna Bear!!!
LMFAO
*wipes tears away from eyes*
what GIRLS do you know that are called Shane honey?!
BAHAHAHAHAHAHAHAHA!!!!!!!!
*whispers*
I think they were men!!!
I worked with a lady who's daughter was name cheyne. Pronounced shane. Weirdo.
LMFAO
*whispers*
lol i didnt even have to reply to that one. thanks anna ;)
cha ching!
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
