Your house? I can think of a few people who might take offence to that bold and unfounded statement.
I can think of a shit load of people that would take offence to it, but I bet my sweet bitch tits they'd rather me call it my house than you!! ;)
Dude seriously, although I do get the feeling you're part female, you're clearly bored and looking for a fight... I'm going to clarify something for you... No one here cares enough about the internet to really fight, especially with a stooge...
So when u get sick of making a fool of yourself, feel free to push the lil X in the top right hand side of the screen....
*by the way, if you don't know your left from right, right's the hand you use to give reach arounds when your having anal sex with your bf*
Anna, this is the way most fully sick honda driving, tight tshirt wearing poof greeks act, they just need to be cut down to size.
thats not what you told me last night man you said that i was your world and you couldnt live without me. What happened??
HA HA HA
FULLY SICK ULEH!!!!!!!!!!!
roflcopter ;)
Better than Shane. Pick a boys name or a girls name, not both. WTF.
i think he means that there is no such thing as a greek warrior, they all just talk big then run away
hi anna :wub:
Morning! :)
herro anna dear :P
HI ;)
Anna Bear!!!
LMFAO
*wipes tears away from eyes*
what GIRLS do you know that are called Shane honey?!
BAHAHAHAHAHAHAHAHA!!!!!!!!
*whispers*
I think they were men!!!
I worked with a lady who's daughter was name cheyne. Pronounced shane. Weirdo.
LMFAO
*whispers*
lol i didnt even have to reply to that one. thanks anna ;)
cha ching!
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
