ha ha ha ha u skank!!!!
I gotta jet off for a bit peoples
:P
be back a lil later
cya :wave:
lol, yeah it is a good site... I havnt been on much since I decided to leave the thing alone for awhile...
Here is another shot of my batmobile :D
that's sexy as man :ninja:
post in that old thread i dug up people.....
its fun....
Smooth Matt :woot: thats a very sexy piece of machinery you have....
:laugh:
hey anna,
does this rag smell like chloroform?
HEY! She did that to me at dinner on Tuesday!
Ben and Anna getting pawned by the Po po......
:ninja:
Anna has dreds now?
Linhs so totaly in love with this movie right now....
Not a bad movie just really shitty ending.....
Hrmmm... he is a little cute. I might have to visit the video store! :laugh:
Thats joe.. She is so in :laugh: with him.... Sheesh...
I can see why hehehe
I have my favourites too!
*drools
*drools more
im bored, its cold, and i need to pee :ninja:
Why are you cold?
Why are you cold?
the stoopid aircon is too cold...not for much longer though :ninja:
And I wish the godamn roadworks men would f**k off! Stupid jackhammers :woot:
ring up the council and make a complaint :laugh:
And where did my Anna go... I have a cute little gif for her :P
no idea, she said she'd be back later *shrugs*
OMG how ghey is work today..
:woot:
*drools
*drools more
He's not that good he does remind me of a Friend thought, Although my Friend prolly would be considered cuter... dont ask :wave:
And where did my Anna go... I have a cute little gif for her :(
Let me just untie her :ninja:
the stoopid aircon is too cold...not for much longer though :laugh:
ring up the council and make a complaint :D
are you gonna blow up the Building?? man it so hot in my office my Balls are sweating :P
HEY ALL!!!!!!!!
and guess wot!!!! got my 2nd 19" LCD at work today!!!!!
only a matter of time until i take over the world!!! muhahahaha
Ps. anyone watch Heroes??
Ive watched up to episode 13 :ninja:
(downloading 14 today)
Its a great show... who do you think is the most useless hero?
still having this debate with my friends...
Out of 10 what would you give the Blonde Cheer leader??
HEY ALL!!!!!!!!
Ive watched up to episode 13 :laugh:
i hate u :woot:
P.S yes i watched heroes last nite :ninja:
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
