i'll swap my car and 5k cash for yours
ha ha ha i wont let my car go for less than 15 cos its so well looked after and never get thrashed... ask shane he can confirm this....
man its done 140 on the clock the engins done 90Km but have already done the 100K service in december... it has 200kws....
man i do really want to get a skyline but i love my sil so much.....
yes this man drives like a bitch :)
urs a S13 sil.. and 5k.. hmm haha i guess ill have to see it sometime at a meet.
the sil has tein coilovers, camber tops, castor tops, reco shimmed diff,
was originally a SR20DE 5spd, 92model. has a 93 180 running gear.
this what he sent me..
Red top Sr20Det 5 speed
heavy duty clutch
custom front mount
Arc bov
400hp walbro fuel pump
Remapped ECU
3" turbo back exhaust, Bee R Muffler
t28 turbo on running 1 bar
Trust manual boost controller
T28 turbo
16" Volk Racing CV Pro mags
Tein HA fully adjustable coil over suspension, pillow ball tops (height and camber adjustable)
Japanese body kit
momo steering wheel
Pioneer mp3 placer
Estimate power 170 rwkw. This car pulls away from most GTR’s running similar boost, but that’s only in a straight line. I have ran a 12.9 pass on it as well.
sounds ok to me.. but yet to see it in person..
thanks shane.. but the R34 will stay as sean drives it. and the GTR will go if anything will go.. ive had it for nearly 14-15months.. time to move on.. DORIFTO... :)
so
1 for keep the GTR
0 for trade for S13 oh and it makes 170kw haha :)
keep them coming..
170kw thats pretty poor......
keep the gtr...and make it 2wd.
heavy duty clutch
custom front mount
Arc bov
Remapped ECU
T28 turbo
Japanese body kit
momo steering wheel
Pioneer mp3 placer
sounds good
but compression &/or leakdown test are the first things i'd be doin
heavy duty clutch
custom front mount
Arc bov
Remapped ECU
T28 turbo
Japanese body kit
momo steering wheel
Pioneer mp3 placer
I would be expecting 200rwkw.....and then it might pull away from gtr's
Edited by Oblivion
heavy duty clutch
custom front mount
Arc bov
Remapped ECU
T28 turbo
Japanese body kit
momo steering wheel
Pioneer mp3 placer
Estimate power 170 rwkw. This car pulls away from most GTR's running similar boost, but that's only in a straight line. I have ran a 12.9 pass on it as well.
the car loks thrashed, does it have an LSD? cos the na sils didnt get them...
if he is willing to give you 12k extra the i would prolly consider it but man that car really looks and sounds like its been thrashed.... so he values he's car only a 8 grand...
but 12.8 at onlt 170kws?? i wonder how fast mine is???
give it to me and ill find out :)
Take it. You don't need massive power for drift. But then again i'm biased :)
yeah reshimmed reco LSD.. should be fine.. uh yeah 12k on top. thats with him getting all minor stuff done. eg wheels, wipers.. prob could get it with 13k my way..
i doubt it will be as quick as a GTR.. not mine :) haha anyway i intend on givin it a beating :laugh: and its a S15 ADM turbo..
first mod... RAS KIT :)
thats doesnt seem possible unless it weighs 900kg.....170kw is not enough to get it doing low 13's
yeah t28 housing are what the sr's use....if it is a t28rs....then it should be pushing 200+
well get the cash up to 13...
then you'll be sweet... you still have the 34 any way.....
T28 only come on the GTiR, S14/15 the S13 and RPS13 180sx use T25 and type x T25g..
the jap spec 15 comes with the T28 BB turbo...
not sure if the Aus spec did though...
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
