that would make a good sticker for the back window of your pineapple so when you beat them in races
"100% australian owned" LOL
If I owned that LS1 R34 I would have that sticker on the rear window lol
They are good engines..they just get bolted into crap cars
yes and no. the first ones we recieved had major problem, until holden finally decided that they would foot the bill to rebuild all problem motors, it cost them millions.
my mates g/f parents had 2 clubsport R8's and they all had major problems, and had to be rebuilt.
pretty shitty for near 70K car
Hmm thats odd my cousin has a 2000 ss super charged and making 330rwkw and has almost 200 000 km on the clock, never a problem
his name is igor from big brother, lol i was watching that show "shopping for love", and he was on there, he owns a monaro ha ha
ha ha I remember him!
Nah it is George Sparlartis GT george!
thats some hella mileage, equates to about 4 months of non stop fulli sik crusing :happy:
He lives in dalby and drives to Brisbane severl times a week..also has family in rocky so he makes that treck alot
Also he didnt have his odo zeroed at 100 000 like the rest of us :)
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
