Age is old new. Pipe down, and listen to the future.
You know it's true. I don't hide it.
I smell pretty anna banana.
My tax is more then most people's income.
How sad for the common people.
Thats aboriginal for more bullshit
revert to my original post....go f**kyaself
Maybe your just so upset because your 52, you decided to have a midlife crisis, buy a skyline and become "cool" again to satisfy the need you never had in highschool.....but your realising that the young ppl don't like you now either...and you're realising how much you really do hate your life? It almost makes me feel sorry for you.
let me guess, this is aborigional for bullshit? Aborigionals really need to learn more words, although I almost admire their simplistic ways of making short conversations.
Obviously being a spoilt brat doesnt increase ones capacity to respond with a witty retort.
Why bother with wit?
My life is alreayd better then yours. Come say high to me at the dyno day, I have the Lexus in primer, i wont be mean to you honest.
Maybe your just so upset because your 52, you decided to have a midlife crisis, buy a skyline and become "cool" again to satisfy the need you never had in highschool.....but your realising that the young ppl don't like you now either...and now your realising how much you really do hate your life? It almost makes me feel sorry for you.
No, quite wrong in fact. For my midlife crisis I bought a used bart simpson figurine. cool again is also wrong. I have always been cool. Wether you like me or not is totally irelevant. I doubt that I will toss and turn worrying about it tonite. And, trust me puppy, I love my life. :(
p.s. wtf is high school?
you know the funny thing, matt and josh dont own skylines, they own TOYOTA's :(
P.S 6 bolt main, niggah please
I've owned more nissans than you i'd say, and all probably had more power than yours as well...so go back to your hole.
Why? cant afford to paint it? do you park it beside the caravan :(
Lets see now
180b
200b
swb patrol
swb patrol
long wheel base patrol
skyline
skyline
lwb patrol
lwb patrol
maxima
lwb patrol (current)
maxima (current)
skyline
and your list is?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
