I told you, next time we are both in Noosa ill take you to the Villa Hotel for awsome seafood lunch...
I don't do Seafood... I do man like steaks though <3
Siff not wine and dine me in Brisbane ho!
P.s u owe me icecream
P.s+1 SAU elite at villa Noosa on a Sunday make it happen
Your just jealous I know how to speak with the lady kind... :(
Just out of intrest, In Ipswitch...
When you go to the local watering hole, when you approach a woman do you;
A. Say oi shela hows about a root
B. Hello there pretty lady, can I try your brests on for size
C. Do you barf on her and yourself and then ask her to marry you so she will clean it up???
Remember your in Ipswitch... Everyone can pretend their Shane and answer this one... :laugh:
Remember your in Ipswitch... Everyone can pretend their Shane and answer this one... :(
a combination of a and c?
Yes i know... If i could post ice cream i would... Maby i should... :(
As for the other idea, hell yes... Ill talk to the gang about it on the dyno day...
Cruise to Noosa for lunch at the Villa... Hell yes...
I sold one of my R32's in Ipswitch once, I had to drop it off for the kid. We waited at teh shopping centre where centrelink is.
never agian....
Im going for option A) due to ehat I saw when I was in the switch..
lol
a happends alot in out back rural towns... like when i was in Inverell... just ask some random chick if she wants a root and she'll say "buy me a drink" Lol
Then we all stalk the local minge for cooter pics?
D. all of the above.. i drove through ipswich once.. damn i saw soo many commodores.. and the ppl in the carpark of aldi ahaha
lol
Speaking from experience???
Sure she was not just a cheap hooker???
Did you get the clap???
a shot at the doc cleared it all up :(
nah thats all they ever do out there wait of centerlink payment then get pissed and root..
like all the girls out there that are over 18 have kids....
all they do is drink and root
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
