So tell me...
is it wrong that we just ordered 2 pizzas, a 1.25L coke, and a garlic bread, delivered, for $25.95....
and we have counted out and are going to pay the delivery driver that amount in 5 and 10c pieces?
that's awesome, but for laughs you should short change him like $2 and see if he counts it.
So tell me...
It’s not wrong, and by law that can’t refuse to take the money as its still current and in use.
We had two run in’s once, one at pizza hut, they weren’t going to take the money in just 5 cent piece’s and once at a servo something like $40 just in silver coin.
Not much they can do hahah SUCKAH!
Ask the pizza boy if you can take their pic while they are counting the coins? Tell them its for sau or something funny
That always happens.
When Tim was a pizza bitch, he said who ever was short had to make it on up out of their own wage, dominion’s rules, flag that I say!
just get ur mate to vid him haha..
VID OR BAN ahaha :(
haha, the guy just showed up... his face dropped when he saw all the coins...
to make it even funnier... he forgot the garlic bread, so he said he will send another driver to bring it over...
I call shenagians.
You'll never see that garlic bread agian
ur a champ..
got pics of his face..?
so he took all the money and counted or just slipped it into his bum bag?
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
