hmmmmmmmmmmmphhhhhhhhhh!!!!
*crosses arms*
awwww there there *pats anna's head*
Might be safer to cross ya legs around this bunch
come on now noel, u know we rnt like that...seriously, we rnt...:P
doubt ull be getting anymore coin :)
obviously u havnt seen the configuration of the bolts of an rb20 in a sivlia...im not a n00b at it either, i've done 8 clutches in skylines so far
and yes, its clean as man! no rust anywhere, no rust on the exhaust etc :P
will see how the inspection comes out today.. :kiss: well if its like the top bolts on most cars ofcourse its gonna be tight its a RB20 box in a silvia chassis.. so ur putting big thing in small room..
was lees clutch slipping.. ill ask him this arvo. im actually quite excited now.. :P
no oil leaks shane?
did u try 1/4 drives on lots of unis? and swivels?
Markimac you are a softcock. get that car to willowbank and drag the wheels orf it. I do have your bash hat so its all good.
No I didnt have sex today, My arse is still too sore from yesterday. BWAHAHAHAHA
haha ur a champ noel. and as if im soft. just call me mark wer past the formalities mate...
so u brought me a bash helmet? u want me to bring the money then?
ill convince my mate to drag his S14a.. ill get a shot in it.. if he does.. i wanna pedal it to a 13.5-14 hopefully :rofl:
will see how the inspection comes out today.. :P well if its like the top bolts on most cars ofcourse its gonna be tight its a RB20 box in a silvia chassis.. so ur putting big thing in small room..
was lees clutch slipping.. ill ask him this arvo. im actually quite excited now.. :kiss:
no oil leaks shane?
ill convince my mate to drag his S14a.. ill get a shot in it.. if he does.. i wanna pedal it to a 13.5-14 hopefully :P
yeah, bring the coin to the digs on saturday. you might have to wait till i finsh one of my 2 hour passes to pay me tho. :rofl:
no oil leaks shane?
clutch is fine dude. only reason he wanted it changed is caus he bought a enw one and lightweight flywheel
no oil leaks either...whats this about ur gtr ahving a split cv? how longs it been split for? hope its still got grease on the joint itself, or theres some $$'s to replace the whole joint.
1/4 drives? :)
give ur car atleast 1 run amrk, just to show lee wat its got ;)...u do the same lee!!! or if ur not man enough i can pedal it for yas :P
I'M BOREEEEEEEEEEEED!!!
I had Hungry Jack's for lunches :rofl:
u'll be complaining ur sick soon :P
i did that for Mark already lol, almost go done by a coppa :kiss: and then launched it at the cop shop lol so silly :P
no no i mean at the drags mate, get a number on paper!
1/4 drives? :P
give ur car atleast 1 run amrk, just to show lee wat its got :rofl:...u do the same lee!!! or if ur not man enough i can pedal it for yas :P
opps meant 1/2inch drives..
the CV boot is a inner boot and wasnt split when i did a service.. but is split last time i checked.. so prob anywhere between 1-4months.. and has loads of grease in it.. its an inner so dnt matter too much and way easier to replace than the right hand side/..
and unless u have $6k in ur bank to pay for my rebuild shane u aint driving haha.. u have a horrible car history.. u prob spend more on mates cars than ur own.. :kiss:
HI5 :sorcerer:
:sorcerer: HI5 BACK YO
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
