OMFG Anna, were these pics taken at your place? :no:
Awww, everything else is right, we just don't have a real life kitty :down:
hahaha, dance mat!!
Don't laugh @ dance mat. I love my dance mat!
Awww, everything else is right, we just don't have a real life kitty :no:
hahaha, yea dance mat is pretty good. My gf has it, i'm getting better at it and it's pretty fun....it's hard though when you get up to and above the 4 feet ones.
I don't know and I don't really care, i'm over talking to you, you're boring me....run along now child and never be seen again.
Are you breaking up with me?! What did I do wrong?! Come on, let me fix what we had!
lol
lol
your obsession with me is normal, however I already have enough fans....back away or i'll get a restraining order.
omg its marc!!!! hi marc :no:
*waves*
Awww, everything else is right, we just don't have a real life kitty :ninja:
Surely you have enough of the "hello" variety to compensate? :down:
push off bish, he's mine rofl.
Looks like I'm going to need to draw up a roster
Hey Marc, is it possible to reconcile my old a/c's like I asked in username change thread? Noone replied to me, I am assuming that probably means it's not possible?
Not to my knowledge, but I'll check it out for you later on if I get a chance
AAAAAAAAAAA$RRRRRRRRGGGGGGGHHHHHHHHHHHHHHHH
I,ve been rooted up the rissole again. Bling wheels wont clear the front calipers. GRRRRRRRRRRRRR. Any suggestions peeeps. :no::down::ninja::laugh::mad::mad:
change your wheels? Alternatively you could grind your calipers...the galleries in 33's have very thick walls....so you can grind off the nissan logo etc and just keep going until you get clearance...you could also get spacers.
Matts dodge option has merit, japtaxi did the same thing. Failing that cut-sick at whoever you bought the wheels from!!!
hi guys..
just finished fitting chris's domeniak FMIC.. ahaha the new just jap ones suck.. i did more custom fitting than fitting and no instructions meant i had to use my well reknown wit.. all in all. was good.
pitty bout having to hack his indiators and seal them up again..
im gonna post a thread up so he can get pics and stuff..
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
