ahaha.. yes shane we all want to be as hard as u :P
and sorry bout makin fun of u choosing a crap out GTR..must hurt u financialy. that should be enough. :)
least i dont own a near stock gtr that's slow as fark :laugh:
oh shane just for u.. performance side. steel wheel turbos. BC running standard boost. kakimoto chipped ecu. exhaust 3" nismo item and highflow panel filter..
that enough for u buddy.. and suspension would make a diference too.
lol dude thats f*ck all :)
dnt think its standard lol...
as if. well i can say this as much as i want both of my skylines run.. and run perfectly fine..
ill cya at tuesday dinner in either one of them ahaha
haha sick, i bethca the gtr wouldnt run a 12 though :P
Talk talk flamin talk Marki. why the heck dont you just have a picture of a gtr hangin on the back of your shithouse door. It would see as much action as your 32. freakin NIL.
night guys,
tomorrow we discuss the comedy option of increasing the discoverys boost.
yes... boosting a landrover!... is it TDi?
i reckon it would run a low low 13.. lucas did on his pretty much stock GTR.. oh well shane be a hater.. ill still love u :P
im not quite getting it.. r u saying noel that i should thrash my GTR? i drive it twice a week and majority on the highway.. got no time to do anything and ive got family to take to school.
anyway.. if i still have it next sau meet ill run it ok.. :P just so u dnt blow a head gasket..
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
