shane... was told to pass this onto you -
Q. Two Ipswich girls jump off a cliff. Who wins?
> >> A. Society
> >> Q. What does a Ipswich girl use as protection during sex?
> >> A. Bus shelter.
> >> Q. What do you call a 30 year old Ipswich girl?
> >> A. Granny
> >> Q. Why did the Ipswich girl cross the road?
> >> A. To start a fight with a complete stranger for no reason what so
> >> ever.
> >> Q. What do you call a Ipswich girl in a white tracksuit?
> >> A . The bride.
> >> Q. What's the first question during a Ipswich quiz night?
> >> A. What you looking at?
> >> Q. Two Ipswich's in a car without any music - who is driving?
> >> A. The policeman!
> >> Q. What's the difference between a Ipswich boy and a Ipswich girl?
> >> A. A Ipswich girl has a higher sperm count.
cut them off!!!!
:laugh:
hmm i could do that, but them itd just be bone on the chair...and thered be blood everywhere, not cool...and id prolly die caus of blood loss, u wouldnt want that now, would you? :)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
