Hope you've made the right choice for yourself anyway Josh, better than court IMO :P
Anyways I'm off...baibai all :happy:
It's a much better choice, however it is a HUGE effort now to get my license back.
I do weird things, I just didn't want to give the Police the joy and satisfaction of beating me.
lol, what did you get cuaght for??
What time? lol.
In short, I was appealing a suspension, and they were opposing it with 4 years of evidence as to why Im no longer fit to hold a license.
I ditched the license, they can't oppose shit now.
i had my dad take my car to a tail shafting place today, to get them to see if the tailshaft was out of balance at all, and i told them if it was to fix it. bcoz i thought it was slightly out.
anyway dad dropped my car back off at my work i didnt get to drive it till 5pm on the way home and when driving it home then whole rear end has a terrible shudder now. worse then ever before, so i think they have over balanced it or something, i dont know why they touched it in the first place if it didnt need doing. that is what i told them anyway... i dunno i give up aye....
Just skid it, it will either get better or worse
:ninja:
so they'll probably impose some sort of restriction withholding you from obtaining your license for x amount of time or something...lol sucks ass but at least you beat them to it sorta....
damn that sucks, just live in hope that one day it will all be good lol
yeah so annoying, so now i gotta take it back to them to say for them to fix it.
hope they do. i just want it back the way it was now it wasnt too bad after driving it now lol
its like some1 has welded some steel to the tail shaft and its not spinning correctly now causing it to shudder, problem didnt need fixing in the first place by the looks of it, it could have easily been something else doing it, but i thought they would know if it was the tail shaft or not? since they are in the business.
thats correct, however the national data base wont get updated, im not even listed as a licensed driver, shows just how slack they are, and only keep an eye on their own state systems.
So, yeh I could go and apply and take the test for a vic license, just have to watch out for where i drive in qld
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
