Hmm might be interesting, I'd be keen to see it if/when it's set up.
I've long wondered about how they'd go with a Vortech-style blower on the side though - simple exhaust, no lag and can be set to make good boost from very low rpm :D
stockymcstock from down south has a twin charge system on his skyline :D
For your mate, $30k. It is regarded as the best looking IS in OZ. And is maintained to that high standard.
Linky http://www.skylinesaustralia.com/forums/in...howtopic=159634
Fark that sexy but no i cant help you out he was looking more in the 20K market lol.... but if i show him he will still be drooling.... cant hurt right :D
Ahahah lee you are one sneaky bastard, i love it! i need some housbricks to steal the rims of the landcruiser across the road :D
but seriously that would still cost a bit to buy rims, then special tyres to clear the defect.
Maybe i could seal the boot and pump the car full of helium :D
lol dude you hav another option....
depanding on how much you have to raise it... get your self a set of old rims and put high profile tyres on them this will raise the car.....
eg... 225/45/r17 was 11cm swaped rims and tyres 205/65/r15 ride height changed to 16cm, just do this to clear the defect then put the old rims back on.....
not special tyres it think its like 500 for a set with steel wheels and retreads...
but i'd go get the stocko's from shanes place, i'm sure you and John could work something out... like say you take them and he can go get stuffed :(
isaac, i have john's old stock suspension at my place u can use to get by. let me know when u can get out my way and ill whack them in for you :(
thanks for the offer shane. Could solve my problems, but heres the problem. I fly back home on a monday - 19th, must present car for inspection to cops by 23rd- that friday. Can you do it on a weeknight? (assuming you have one of those cushy 9-5 jobs :D wish i had one :D ) I could obviously bring the car to you.... guess it wouldn't take long to install stock suspension?
but i'd go get the stocko's from shanes place, i'm sure you and John could work something out... like say you take them and he can go get stuffed :D
ahah again mr lee, i likea tthe way you think :D
hahaha guess not...
$20k??? he will get a bucket of crap IS for 20k
LOL other Matty got his for like 19K :D and its quite nice... well they deffinatly wont be up to standard of your car... dam drool...
only takes 2 hours mate. more than happy to do it for you after work :(
what is the legal height requirement in qld?
farking 15cm... they are really cracking down on it too....
lowest point :D can be basically anything the want exhast lip any thing....
on that not so how do you get a RWC for the IS Matt??
okay cool :) i'll let you know. Got quoted $2200 for tein super streets so really wanted a cheaper option lol. The locknut is busted on the coilovers on the right rear but as the adjusting nut is siezed i dont think its ajusting anywhere atm :D ... i hope :D guess if that goes when i'm doing 110kph on the motorway i'll have some brown trowsers lol
its 10cm unless things have changed. My car passed inspection at queensland transport at the height it was, yet i got defected by the police a year later go figure? The only point of my car that is lower than 10cm is the rear part of the exhaust, its 8cm off the ground.. the bodkit etc is 13cm at its lowest point (i know cos i measured it aaaages ago).
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
