Hmm, i'll do $30k @ 6.45% over 5 years.
You set how much u can pay each week, catch is, by the 5 years if your behind I will brake your legs.
sounds good.... where do i sign....
are you being seriouse cos thats a cheap ass intrest rate, under the table? ;)
I can't release 30k right now, I have cash at home, but I want a higher rate for a smaller amount...
Im serious, I will have your f**king legs broken lol.
Im a nice shark, I let them set their own weekly repayments.
lol, i kinda just wana brake lee's legs though
fcuk letting them set their own repayments....means either....you're out of money for 4.5yrs...or you have to wait 5yrs to break their legs....either way it's a downer....Interest only payments for the first year then decreasing principal payments for the remainder...missed payments means missing fingers...and it only gets worse lol.
I know how it works, but Lee is nice, he gets a decent deal.
dude sif i car i will have it paid off buy then.... i'm just being tight right now and can't be f**ked using a bank, cos they farking charge you to much...
i just wanted the money to buy this it makes me happy
you c**ts are really nasty c**ts....
nah the missus would kill me cos we gotta buy a place like next year.....
but dude thats cheap as.... lol thats only like 700 a month to pay back...
i no understand you :P
Ah Long (derived from Chinese word "Dragon" (Chinese: 阿龍) or short for the Cantonese meaning "tai yee loong" which loosely means someone with huge earrings worn so heavily that the earlobes elongates) is a term for illegal loan sharks in Malaysia and Singapore. They lend money to people who are unable to obtain loans from banks or other legal sources, mostly targeting habitual gamblers. They charge a very high interest rate (around 120% p.a.) and frequently threaten violence towards those who fail to pay in time
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
