prolly only since word has gotten out they built marty's DRAGME
Built that ages ago though....and they've built heaps of tough cars prior to that. I've never been there or anything but on the face of it they must be half alright.
rofl @ Pablo in that FS thread, how come each turbo puts out 550hp but the car only makes 430hp hahahahahaha....
obviously he's a farking n00b :dry:
talkin to marty he said they're slow as fark though
hahahaha yea!! Man i'm going to build a 2000hp car with two 1000hp rated turbos phwooarrr!!!! n00b's, fair enough he doesn't know but why would you ask that question in the guys fro sale thread when you clearly have no idea....
slow turnaround is usually a common price paid for good work from busy workshops....as long as it's not rediculous I suppose......if the end result is worth it.
took over 2 years to build marty's car at 101, id say thats pretty sheit lol
Dude without a f**kin boner i would still have a bigger ewang than you.
noel, ur forgetting lee's asian :dry:
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
