Definitely not. To me it simply looks out of proportion to the rest of the car.
You must need to get a new prescription at the optometrists! Here is the same front bar on my old poosar!! Looked tight!
On a gtr they are awesome. but the larger front on the gtr carrys the bar far better than the shrunken fronted gtst.
The bars are completely different to the actual gtr's, they are made slightly smaller to suit gtst's and on my car I flared gaurds and everything. They look good, just admit it.
Yes i'm a terrorist, from Dubai. I love skylines, and I plan on buying one when I get settled into our new place. As I said I have been a long time forum reader, and now I'm comming to Australia I have signed up.
Would you please do a live practice run with your strap on bomb kit before you blow up our dinner. :(
Quite frankly its everything i hate in a bar. just way too much of everything including size. No sense of proportion whatsoever.
Yeah dont mind that Lee.
i've had that bar before, hated it, it was way way too low. Hard to tell from that pic but its much bigger than it looks. Thats what I had before I changed to the gtr bar. They also have a weird v sorta thing in the middle. But it's still a relatively nice bar. Much nicer than standard series 1 bar.
I thought the Australian way of life would be a lot more welcome and open arms to people visting. I guess we were wrong.
yes ur correct there too, series 2's ftw!!!
P.S i miss my old 33, that pic makes me sad :(
Yea, i hear you. I miss my 33 when I look at old pictures. I wish I had my first 33's looks but with my second 33's engine lol. I wish I had this really...
it's hot.
this is so someone (like josh) taking the piss. Otherwise why wouldn't you tell us who you work for and where abouts you live??
You werent wrong. when you get to meet us you will realise its all in fun. Now stop whinging and start posting crap like the rest of us.
why buy a Skyline if your only gonna be here for a year? after you buy it advertise to sell it straight away cos thats how fast Skylines are selling ATM...
if you can't stand the heat get outta the kitchen son....
if you dont understand..... GTFO nOOb
Why would I tell you the company I work for? What possible need would you have for that information?
What company do you work for? Do they know your wasting productive time typing on a site for Nissan Skyline?
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
