S'matter fatty. Your little dick too hard to find so you can stand up to piss.
see what i mean >_<:ninja:
you lucky your an old man and i have a small penis... or i would be very up set :wave:
drama?
lol nah, been busy as fark all morning and just cbf doing anything else
i hate people who can't spell.
Me too. I was a speling champeon at school though so my posst shoudl be eesy to reda.
Tell me more about these 10hp ecu mod thing u spoke of on gsx the other day
link?
Celicas? Ew.
i think the reason you lot were all banned, is because you came to Boost with the sole intetnion of shit stirring, as can be found back a few pages in this whore town thread. this was found, and obviously acted upon.
i do understand where you're coming from with the double standards, it happens, and i know im not the most liked person on Boost, many times warnings given to me, but exempt from others.
i didnt come here to stir shit, more with the intention of calming shit down a bit >_<
get her to remove the bans, and then things will settle down.
or this may just keep on happening, and ban's wont stop us, there are ways to overcome bans if we feel the need :wave:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
