seems like u have no respect end of story.
dave, we wouldnt be so uppity if we only got 'banned' on boost, but it has dragged over to SAU, and this is why we are 'uppity'.
Fair enough if people complained about us when we were in the whore thread on boost, but no1 in there did, except for a certain mod, which put the 'ban' on us, and then obviously some1/s have come over to SAU, complained again, and yet the first mod told us to stop (which we did) a second admin came in some numerous hours later and gave us all 10% warning, which is complete bs.
So sue me? I'm a pretentious little up-start brat from Noosa, who hides behinds his fathers money and always gets away with rubbish.
As I keep saying, take a ticket to sue me, no one has won, yet.
A+
Sum's it up perfect.
Well, at least your honest.
Dunno wtf you're talking about RE: bagging you. She's said nothing about you specifically, although I certainly have.
for fu<k's sake, wake up to yourself.
any more bashing of Boostcruising or its members by anyone in the QLD section will result in an immediate 7 day ban.
jeez mud settle down, it was a joke, and even if it wasnt it was not aimed at any one in particular nor was I involved in the original incident. :laugh:
You are much more than that you tosspot. You are also Jobless, licenseless, and your ride is a woodridge special. Get a haircut and join the army you bum.
p.s. I was owned you camel jockey. LOL
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
