Nothing much, i tore a ligament playing basketball on thursday.....so I spent most of the weekend with my feet up watching tv/dvd's and playing xbox lol.
How bout you?
ouch man, not cool
worked on the car for a bit sat, n then watched the v8's for the rest of the weekend
ouch man, not cool
Yea, I know. It sucked...couldn't really walk or do anything...it's starting to feel a bit better now though. My gf was paying me out all weekend about how I walked like a retard...really kind rofl.
soo what did everyone get upto on the weekend?
Went to the gymkhana event at the Gympie skidpan MY GOD, so much fun, cams approved event ect.
Friend won the 6 cyl class in his gtst, we need more SAY ppl at these things
SAU even
Lolz @ SAY people? wtf
yea, i was wtf'ing....who won??
Michael won the 6 cyl class in his R32
v8 commo won the 8's and the white station from Mdore won the 4 cyl.
Was an ok turn out, they want more numbers, it'll happen over time. The muzza on the stop watch is a little lazy and a few of the runs in the gtst we felt were quicker. Meh, won anyway.
Yea i heard bout most the boostlosing stuff from josh..don't see why that means whoretown is now being strictly watched/moderated?? Way I heared it, josh, lee and shane etc went over to bc and paid out some ppl, a mod (who, from what I hear, is a friend of the person insulted) chucked a spaz, threw out some ban's on bc and warning points on sau. Sh*t hit the fan...but I mean honestly...meh!! This has nothing much to do with SAU nor whoretown....
correct,
the nazi occupation of whoretown is a separate issue to the BC v SAU shite.
Anyone with an R33 and a multimeter able to help me out? I need to know what terminal is -ve and which is +ve on your map lights.
It appears R34 have a -ve for the tip of the bulb and +ve outer...R32 are the opposite and R33 I have NFI?????
Can someone measure it and get back to me (PM please)
thanks.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
