maybe it'll spice up their life
that or a copy of Spiceworld: The Movie
Have you met lee? nothing could spice up their realationship, he looks like a dodgy fisherman!!
Jokes lee, you know I <3 u
Edited by Mr Kofi Ahmed
Hey everyone, won't be on till prolly after lunch todays..
Got this morning tea etc for my going away
:P
Just though i'd drop in and say GOOOOOOOOD MORRRRRRRRNING!!!!
hey missy :kiss:
good to hear ur making the best of ur last few days there!
:sick:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
