yeh coz its not a real HKS ;)
Serious though, what else do you have? What power are you making at what psi and where? Simons maroon R33 is a self tune, self built and makes 270rwkw give or take everytime minus on an allstar dyno
Apexi AX53B70 rebuilt engine, cams, power FC 230rwkw at 14psi at allstar
while I love drags i will be doing sprints as well. so the turbo selection is critical. Will definitely be looking at pon cams and adjusto exhaust gear as well.
the stage 3 hiflow of which i speak is the slide variant. will look for specs later.
Prawn cutlets and seas scallops. mmmmmmmmmmm
why not a 2835 range turbo then...??
Thats what I said too, i was leaning towards the 25/40 as i thought Noel wanted his car for track, untill u said other wise. the 2835 would be a shoe in, with sane boost levels.
Get a HKS 2835 and call it a day Noel.
Indeed, for Noels application I think it's 2835 FTW!!!
2835 for sure. room for the drags, nice match for the track.
I have tentively bought this, mate is in sydney this weekend and will check it out.
http://www.skylinesaustralia.com/forums/in...c=80164&hl=
jesus that is old....was looking at it for a replacement engine when I punched the rod out of my old 33..that was almost 2 years ago!!!
Bit more then just a set of forgies.... If what Andy is saying is correct see if you can go for a ride in that car, a 3037s making 1bar at 3000rpm is NUTS.
so, 3000rpm with a built motor, with head work and the tomei cams u speak of will make me jizz
ya. it will need to be looked at closely to make sure its been stored properly.
3000 my ass. wink wink.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
