Well f**kya then Zaff, I was trying to help you out but you wont rerspond so forget it.
Hah sorry noel my computer decided it would get aids and I had to pop out this arvo!
No I am not a member as yet but am planning to join shortly as I have just gotten my license back as you already know!
kthnx...
Cliff notes:
Ive been a real estate agent since I was 18.
I dont have a car license, i need a part time job close to my house.
I applied at woolies.
oh, in that case, fair enough. Why dont u have a car licence?
17 - now Ive been a complete cock tard, went to court on another matter, police complied evidence over the last 4 yrs trying to prove I was unfit to hold a license and try and give a longer suspension. I surrendered my license to try and beat the system, no license no court.
No court meant a longer suspension cant be ruled. I ended up with getting the min time.
Which is?
good plan!
Cliff notes:
Kudos to you for getting off your ass and havin a go dude.
my lil bro just got his P's and got his first fine on the weekend and was absolutely deverstated cuz he didn't do anything (car near him did burn out, he got picked outta crowd). Hence the reason why 17yr old boys driving loud skylines shouldn't drive in mooloolaba on a saturday night! Told him to get used to it and avoid the area!
What the?
LOL at Josh workin at woolies
Imagines Shane asking him "are those bananas firm?"
Nismoboy replies "Do want a fist in your face?"
I wont last working at woolies aye. I need an admin job so i can whore on here all day
Yeh had to do something, sitting on my ass is boring, and pointless. Im spending more then I earn, which is a big fat ZERO. Woolies will suck, and I doubt i'll last, but its "something" I guess.
Plus its not even 5 minutes up the road.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
