Should I tempt fate and attend the may 17 track day?
I am thinking I should relearn braking with the new set up before I head to Wakie....but then I am worried about braking something before wakie lol
Better to break it close to home than 1000 kay away andy. Give it a run bud.
So this long story about Kofi, what is it?
back in 04 i think, some spammer signed up as "koffii Ahmed" was like mass sau pm's trying to offer money scams from memory.
he was deleted, i made the same account, but I cant remeber the pass word or the email used, so i made this new one, but kofi, not koffii.
somehting like that anywayl
Well I can answer that with a yes...not all are try and tested by me however....feel free to stalk away though...dont blame me if your rejected for not being rediculously good looking....like me... :laugh:
Im LXU55 (was). This isnt an issue.
Brakes, oil cooler, radiator, centre bearing and tune fix...how many days do I have left???
about 2 weeks worth of days bud. Yell if you need a hand. Its been a long time since i swung spanners in anger but i am sure i can contribute somehing.
I meant zaff's, he had hot young toeys on his
what where?
no tempting fate, like u said, give them brakes a good run in on the track up here and get use to them, so if anything does go pear shape, u'll ahve time to fix it b4 july!
so therell be no excuses for when i whoop ur butt :laugh:
more boost, IT NEEDS MORE BOOST!!!! :)
P.S blown headgasket anyone? :laugh:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
