lol... i would of told her to f**k off...
Same.
I believe people choose to be poor, or choose bad reasons make them poor. It might sound harsh, but its true. In saying that we are at a stage where the parents who have made these choice's are in turn shaping their kids.
The evil centrelink cycle, its all the parents do, thus its all the kids know
Edited by Nismo_Boy
Same.
The even centrelink cycle, its all the parents do, thus its all the kids know
precisely, they are caught in a trap and unless by accident or providence they find their way out they are doomed.
Thats crazy. God that car moves, I was going to goldy and stired im up something silly along the highway near the highport. I wa sin the lexus, so damn well knew it was dumb, i guess he didnt see it like that.
hmmm...
its the old i CBF/ someone else will do it attitude that traps them, if they had the strenght of will and the determination they could easily rise above the others, also something about tall poppies...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
