yeah thats always good cause then you can leave the place in a like crap and not have to worry about cleaning it...unless you get her to clean up on her knees...
oh new topic...
is your car going yet shane.
Silence Rb20 owner >_<
Means I gotta go get my 18+ card. Now that is effort
pfft fark that, just trawl the streets up there :sick:
Are we any wiser as to how long you will be without a license as yet. AND....will you fall under the new p plate laws when you do get it back.
I would have had it back next month if it wasn't for a SPERS fine I had and never paid, that I only found out the other week, so its not a big deal as I always thought I was getting my license back in another 5 months anway.
Annoying yes, date didn't change so i'll live.
5 months time I reapply, and roll back onto my opens, and 12 points.
!WOOOT! thank goodness for that. otherwise it would be another 4 years of driving boooring shit.
Are you going to pimp out another hot ride?
You make me cry Noel, Nigga please - Pimp? once, and once only. NEVER AGIAN!
If I don't buy a performance car straight up I'll flog a few cars from auctions to put towards a motor.
In terms of what performance car I would buy, Im not sure. I was with a built rb26 on the weekend and it made me think... In a good way. But I still deep down want toyota love
That thought had crossed my mind. I however I aren't an open budget unless some miracle happens I and a land another awesome job
Saw a boganed rb30 at the bank on saturday night, 2j auto with everything home meade and the farkin thing still ran 11's
1.5JZ all the way man.
Did some serious in depth research to this. There is no hard core evidence that the 2jz head flows better/more then a 1jz head (stock). So unless I bought a car with a 1jz already in it, I would just go a straight 2jz.
EI: I wouldn't build a 1.5j for the hell of it to put in a hybrid car. Nissan/Toyota conversion for example.
no i was being serious shane...what is needing to be done before it be going?
i have an rb20 for the moment....
ok, well dry sump setup, exhaust, and ecu is all thats left
however how long that will take depends on if i get this dog box on the weekend >_<
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
