yeah thats always good cause then you can leave the place in a like crap and not have to worry about cleaning it...unless you get her to clean up on her knees...
oh new topic...
is your car going yet shane.
Silence Rb20 owner >_<
Means I gotta go get my 18+ card. Now that is effort
pfft fark that, just trawl the streets up there :sick:
Are we any wiser as to how long you will be without a license as yet. AND....will you fall under the new p plate laws when you do get it back.
I would have had it back next month if it wasn't for a SPERS fine I had and never paid, that I only found out the other week, so its not a big deal as I always thought I was getting my license back in another 5 months anway.
Annoying yes, date didn't change so i'll live.
5 months time I reapply, and roll back onto my opens, and 12 points.
!WOOOT! thank goodness for that. otherwise it would be another 4 years of driving boooring shit.
Are you going to pimp out another hot ride?
You make me cry Noel, Nigga please - Pimp? once, and once only. NEVER AGIAN!
If I don't buy a performance car straight up I'll flog a few cars from auctions to put towards a motor.
In terms of what performance car I would buy, Im not sure. I was with a built rb26 on the weekend and it made me think... In a good way. But I still deep down want toyota love
That thought had crossed my mind. I however I aren't an open budget unless some miracle happens I and a land another awesome job
Saw a boganed rb30 at the bank on saturday night, 2j auto with everything home meade and the farkin thing still ran 11's
1.5JZ all the way man.
Did some serious in depth research to this. There is no hard core evidence that the 2jz head flows better/more then a 1jz head (stock). So unless I bought a car with a 1jz already in it, I would just go a straight 2jz.
EI: I wouldn't build a 1.5j for the hell of it to put in a hybrid car. Nissan/Toyota conversion for example.
no i was being serious shane...what is needing to be done before it be going?
i have an rb20 for the moment....
ok, well dry sump setup, exhaust, and ecu is all thats left
however how long that will take depends on if i get this dog box on the weekend >_<
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
