whats pannein josh?
found a job yet ya farken bum? :(
1) NFI
2) I still have that stock broking one pending, the principle broker isn't in the new office yet, I can go on as admin at one of dads company's, but the other directors want a trainee and I said no way in hell I'm doing a traineeship fixed on $380 a week for a year. I rather sit at home getting $480 a fortnight on the dole.
I'm considering applying for a few laboring jobs in Brisbane, base wage for them starts at $760 per week. I bet a weeks wage I leave within a weeks work.
1) NFI
yeah stuff bein a trainee, and yeh i reckon you'd quit after the first week lol
Loz at the edit. I was like WTF does pannein :(
u mean lolz, yeah? :(
I hope teh aircon is already gone??
obviously you didnt see the pics i posted up awhile ago :(
i've removed the aircon, all the plastic vents behind the dash, the heater box, control unit and every wire assocaiated with it :(
someone tell me how come it takes 5 HOURS TO FRIGGIN WASH A CAR =\
all the repairs are done, but they have to wait for their detailers to come and clean it before they give it back to me. Dag nab it, im suffering withdrawal symptoms.
I love weight reduction more then anyone, but I love my heater, or atleast need window demist! lol. Those f**kers fog up in the wee hours in winter
only 5 hrs? thats pretty quick lol
when i detail a car, it takes me 1.5 days :(
the guy who i bought the seats off last nite, has a very mean track 32 gtr, and i as having a good talk/look over his car, and i'm a bit off put by the pedal box, to get it in and working u have to either:
a) mount the seat back further and extend/modify the steering collomn (sp)
b) cut the floor/firewall
he has the first option, and i wouldnt be happy with the way ur positioned
:D
:D
He has the floor mounted pedal box GTR thats always at QR?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
