This message is for the old fart (Noel)
Mate i cant make it to willowbank this wednesday, somethings come up and ill be in Kingaroy for the night on Wednesday... :(
But Ill get her ready for the next one, pitty its so close to winter nats tho as it will be uber busy...
i might need protecting too andy.. will you hold me ? :P
Ever so tenderly
p.s. i put a myspace friend request through 3 days ago.. where is the love :(
Sif I get on myspace more than once a week
Sux to be you
that..is hot!
Specs? Release date?
yeah specs on that thing, it looks sexy
erm... here are two articles...
http://www.dpccars.com/photos/05-13-07page-Audi-RS5.htm
http://www.drive.com.au/Editorial/ArticleD...ArticleID=25397
hows the ceffie going donkey_punch? (ive see it from time to time when i drive past dans place)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
