A saw a mighty boy for sale, it says 4wd turbo.
So i had a closer look and year it was fully evo running gear...
The owner says its stock as a rock and runs a 55 lap round QR sprint... Thats quick as...
But when you car weighs less than 600kg's i guess thats expected... :)
looks good dude :)
what paint did you use? acrylic yeah? and ya wanna do a certain gtr? :banana:
Yeh used Du Point acrylic. My brother painted the car, he needs more practice before he did an out side job, just been doing mates car for around 8 months.
Well im off to my "State of Origin" lunchen, then onto the XXXX brewary and then on to the game to enjoy front row seats on the 50 metre line and then back to XXXX keg room to finish the night off...
Enjoy your day people... Ill talk to you all tomorrow night when Im sober again... :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
