Bah i got one of our unit people who is a mechanic to give me a hand with them cams, everything going well, and then bang, fkn broke a stud of I6 capstud, didnt even move a bit broke straight away, You would have a spare bearing stud would ya dan? i need one or know where i can get one, IE: repco?
if ya talkin cam bearing I can loan you one and you can replace it. I will need it next week tho.
And yes i followed the correct procedure blah blah blah in how to remove cams etc before ANYONE asks. Yes i have a torque wrench, i also have the manual and i took extra care etc etc didnt rush it....
Cheers
A
You won't be able to get one as they are line bored to match the head. The one you lend will not necessarily be the same as the one you get back
May not fit
Studs aren't available from anywhere really. You gotta use a M6 cap stud or something similar and tap the hole out to suit
You can helicoil too if you like
You can buy replacements for the rb26 the tomei ones, but i just need one not 28 of the fookers, and it happened to the intake or bearing cap I6 as numbered on them the one with the brass plate attached to it, and yes dan is correct about the bearings as there machined for that specific engine, looks as if it was going to break either way who ever did it as it broke almost instantly first slightest pressure on the damn thing....
Bit of stud broke inside :O thats what i thought about the stud theory should be able to just threadtech the old one out and replace the stud like any studs head manifolds etc
That what i thought too Adam.
Hello Queenslanders... im coming up from 3 to 13 june from Melbourne, ive been before but would like some ideas on.....
what to do and where to go
and
What are some good places i can hit in Brisbane City?
And can someone tell me what is with the terrible taste in cars/mods in QLD.. like lancers with big chrome wheels, vinyls and pink interiors etc...
thanks :O
and
thanks :O
The dunrootin old folks home does bingo every tuesday night and the pink Lancer belongs to Adam.
the name 'adam' sounds about right for a pink lancer, and bingo on a tuesday night sounds delightful, i want to yell out 'legs 11'..... then all the old ladies can show me their legs and then :O
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
