Mr policeman that i had met before, didnt seem to like the ride height or this...
rofl, that was ubber funny:
Cop: Whats that mate?
Brad: huh?
Cop: that dump pipe?
Brad: Oh it's stainless steel
Cop: Yeah, I know that what is it there for?
Brad: Performance, high flow!
Cop: Uhuh, but why is it there?
Brad: I do some trackwork now and again...
Cop: Yeah, sure you do....you know what i'm talking about.
LMFAO...way too funny.
So today I try to do the right thing and wash the car with a bloody bucket. It sux. Mrs comes home and I proudly brag how i did it only to be shit canned by her because we cant even use a friggin bucket now. Like, WTF! Am i sposed to piss on it to wash it or what?
when you are in the shwer sit a few buckets in the corner, they will fill up and you are allowed to use that water!
I like to be dedicated
P.s, dyno day take me for a drive in your car!
bahahaha ur gonna be waiting about 4 months i reckon :laugh:
No sweat, maby we can cram shane in the back also, kill two birds with one power pole I think the saying goes...
sorry, i only go in fast cars these days ;)
Hey whats doing old man???
Put the slicks on my car to come out to willowbank last night and found they dont fit...
Scrub in the guards bad... Need to get my guards rolled before I can run the slicks...
Need to get the car into the smash repairer this week also for the front bar and other little stone chips and shit...
But yeah im looking forward to the bank and a 11 possiblly a 10 second qtr...
i'm willing to put $50 down and say u wont run an 11 on ur first outing :)
I up for hitting the bank next state of origin :D If all goes to plan that is
sweet, which one, commonwealth? westpac? bendigo? :sorcerer:
no probs, I have 1/4 mile mapped out on one of these "private" roads :rolleyes:
is it out in the MIDDLE of no where? ;):whistling:
caus we're not spose to 'waste' water on cars (fark em i say, i still use the hose to wash cars :P)
is the ceffi up and running again ben?
yes indeed, ordered the new radiator and thermo for it on wednesday, should be ready in about a week.
front swaybar is in, rear swaybar and remote oil res. coilovers are sitting are sitting at dans waiting to go in.
its just running base maps for a while, still searching for a half decent tuner.
ok, well have u looked into cnj?
they tune mark & russels car (giant on here) and tune a guys pretty serious gtr that lives 2 streets away from me. could be one to look into
yeah ill look at it, also may have stumbled onto a guy that tunes v8 supercars for a living.
Happy to hear the ceffy is all up and running again ben. Congrats.
thanks man its been a long wait, but its gonna be sweet as this time, just need more cash to get everything setup as i want it.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
