for once im actually jealous of something u own shaney poo..
ima gonna tax them!
as if use a GTR pump anyway...
i got a spare CA pump if u want that.. im sure ur car would love a light weight CA pump :P
aww thanks marki :domokun:
im usin the rb30 pump, s'all good :P
noel & i are now masters of braided line :sorcerer:
although at first we were 'this' close to giving up, caus we couldnt figure out how to cut the hose properly without it fraying/flaring :fakenopic:
no trade...
i ended up going noviated lease, so no trade ins for lease under any circumstances...
Who did you take the Novated lease out through? I've spoken to a few company's in regards to what each one will offer me. For a laugh I got a quote on a un maintained lease on a GT3... Crazyness.
$1400 a month for a STI or an EVO seems to be okish.. So much commitment though
Im having no bites from sau...
All my phone calls have come from carsales.com.au go figure...
That said im yet to find a serious buyer, everyone just wants a test drive...
ever want to sell a car use carsales. i had all up over 15000 people click on my ad to view it. and around 500 calls over the months i was selling it. soo many people wanted to drive only 3 did.. and the 3rd brought her well traded :) . :(
although at first we were 'this' close to giving up, caus we couldnt figure out how to cut the hose properly without it fraying/flaring :)
how did u go about it.. im interested..??
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
