if you run a greddy plenum it will open up the top end and it shouldnt nose over...probably need a good exhaust manifold too (6boost). Our gt30 .82 rear went to 320rwkws without water injection and it pulled all the way to 8k redline. Remove all possible restrictions in the bolt ons and you can run the smaller puffers further to the edge without losing power.
Im up to 332rwkw now on 21psi and still have stock cams...
So a goal of 350rwkw (which to be honest is too much for a daily driven car) is easily achieved from the Garrett GT30R also know as the GT30/40...
Im at 21psi by 4000rpm btw, so its quite streetable, just farking stupid round town when it comes onto boost and jumps sideways... :unsure:
So i turn the boost controler down to 16psi where it makes just on 280rwkw and thats far easier to handle round town... :O
Im at 21psi by 4000rpm btw, so its quite streetable, just farking stupid round town when it comes onto boost and jumps sideways... :O
So i turn the boost controler down to 16psi where it makes just on 280rwkw and thats far easier to handle round town... :P
thats promising. i said noel's car will break the 400rwkw mark, and if ur results are anything to go by, he should do it fairly comfortably :unsure:
all noel's has to do, is pick up 69kw from 4psi more boost, cams & massive headwork, piece of piss i reckon
Easy.
if my bitsa can can 490rwhp/365rwkw on a td06-25g with t78 wheels on 1.5bar (3800rpm) Noel will piss it in
Fkn A doggie, shouldn't be a problem. Andy got 306rwkw on 18psi i'd like to see them bump it up to 22 or so and see what he can get. He doesn't think it'll be much of a difference but with the new fuel pump and shiz he shouldn't be running out of fuel like last time. I'm trying to convince him to go back to chiptorque, best tune we ever had was from them.
theres heaps of stuff on youtube, theres a clib with arabs drifting a Carrera GT and a McLaren Mercedes SLR....
I too am watching youtube clips...
cept i'm reminiscing so mine are in the form of
http://www.youtube.com/watch?v=wor-Z4SyWCg
http://www.youtube.com/watch?v=Qmve365Ti1k
かわいらしい さくら - MISS KITTEH! says:
haha and I wasn't a fan of human nature
except for one track which was very BSB/nsync
Josh says:
some one will think im queer when they see this history
bahahah it will just confirm rumours
Josh says:
they're only true when im drunk
Josh says:
lol
z so i'd find you at the beat then?
hehe
Josh says:
they sell cheap drinks
Josh says:
quiet u
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
