ahaha..ok..
hmm tossing up the idea of buying a a/m FPR or seeing if the standard one works with 740cc.. which sound be flowing 60% at 200 but im going for 240kw. what brand.. had a malpassi before.. not impressed.. perhaps sard..?
perhaps ill try with the standard..any suggestions
*clears throat*
ha ha
Who wants to drive my car to a good drag time? I couldn't be bothered ha ha
i'll do it.
and i'll try not to blow this one up :)
noel...old man and me are going to keep the greddy mani on for now and then later do a straight manifold swap and do some back to back testing to see dyno and real world difference between greddy and plazmaman on a built motor....how does that sound for ya? We were arguing about it all afternoon....stupid old man, annoys the hell out of me sometimes. Just need some egt sensors in every port or lambda sensors for every port to monitor afrs for every cylinder. Hopefully we will cover most bases, not only will it help with tuning it will help log the results in terms of airflow for each cylinder and whatnot.
Completely random...but i rememeber that thread we were talking about whats better and whats proven and blah blah blah...so here is our chance to actually do that for everyone.
pyro's in which side, intake or exhaust? i remember reading on here somewhere about them and the general consensus was that they'd interfer too much with the air flow
Your man cans are growing bigger by the day. You'll be sitting down to piss next. :laugh:
i thought he already did :)
ahaha..ok..
y do u want to adjust the fuel pressure? if u've got good injectors and a good fuel pump, u shouldnt need to play with the pressure.
doesnt have to be full on racing...even just sprints or the time attack days even top gear.
drag and drift is all over way too quick....wasnt meant to rhyme either.
haha or maybe it was... :D
Edited by r33_racer
nah prolly just a T04Z. My tax return wasnt quite as large as I would have liked
That list on his msn is his list.
that'll still make ~700bhp. well so dan reckons. haha always the way isnt it
ahh i see, we mite see it running in another 5 years :D
well he has to do my engine, check your clearances, and the million other things that he does to help people out.
apparently some tuners prefer being able to dial in more fuel pressure.. and also i wank the wank factor :sorcerer:
just gonna run 740cc nismo direct fit. i forgot what brand pump i got. im ordering the turbo thru aaron 3071R 56 (slide) unless someone recommends otherwise..
maybe ill talk to dan
ahh i see, we mite see it running in another 5 years :)
ahaha coming from u shaney poo.. LOL :D
he's a wanker, get dan to get them for ya
u know its bad when i pay ppl out for build times lol
thaqt would be a good idea, he has the best garrett prices around, also i might be selling my GT2876R .64 T25 flange????
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
