ahaha..ok..
hmm tossing up the idea of buying a a/m FPR or seeing if the standard one works with 740cc.. which sound be flowing 60% at 200 but im going for 240kw. what brand.. had a malpassi before.. not impressed.. perhaps sard..?
perhaps ill try with the standard..any suggestions
*clears throat*
ha ha
Who wants to drive my car to a good drag time? I couldn't be bothered ha ha
i'll do it.
and i'll try not to blow this one up :)
noel...old man and me are going to keep the greddy mani on for now and then later do a straight manifold swap and do some back to back testing to see dyno and real world difference between greddy and plazmaman on a built motor....how does that sound for ya? We were arguing about it all afternoon....stupid old man, annoys the hell out of me sometimes. Just need some egt sensors in every port or lambda sensors for every port to monitor afrs for every cylinder. Hopefully we will cover most bases, not only will it help with tuning it will help log the results in terms of airflow for each cylinder and whatnot.
Completely random...but i rememeber that thread we were talking about whats better and whats proven and blah blah blah...so here is our chance to actually do that for everyone.
pyro's in which side, intake or exhaust? i remember reading on here somewhere about them and the general consensus was that they'd interfer too much with the air flow
Your man cans are growing bigger by the day. You'll be sitting down to piss next. :laugh:
i thought he already did :)
ahaha..ok..
y do u want to adjust the fuel pressure? if u've got good injectors and a good fuel pump, u shouldnt need to play with the pressure.
doesnt have to be full on racing...even just sprints or the time attack days even top gear.
drag and drift is all over way too quick....wasnt meant to rhyme either.
haha or maybe it was... :D
Edited by r33_racer
nah prolly just a T04Z. My tax return wasnt quite as large as I would have liked
That list on his msn is his list.
that'll still make ~700bhp. well so dan reckons. haha always the way isnt it
ahh i see, we mite see it running in another 5 years :D
well he has to do my engine, check your clearances, and the million other things that he does to help people out.
apparently some tuners prefer being able to dial in more fuel pressure.. and also i wank the wank factor :sorcerer:
just gonna run 740cc nismo direct fit. i forgot what brand pump i got. im ordering the turbo thru aaron 3071R 56 (slide) unless someone recommends otherwise..
maybe ill talk to dan
ahh i see, we mite see it running in another 5 years :)
ahaha coming from u shaney poo.. LOL :D
he's a wanker, get dan to get them for ya
u know its bad when i pay ppl out for build times lol
thaqt would be a good idea, he has the best garrett prices around, also i might be selling my GT2876R .64 T25 flange????
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
