ahaha..ok..
hmm tossing up the idea of buying a a/m FPR or seeing if the standard one works with 740cc.. which sound be flowing 60% at 200 but im going for 240kw. what brand.. had a malpassi before.. not impressed.. perhaps sard..?
perhaps ill try with the standard..any suggestions
*clears throat*
ha ha
Who wants to drive my car to a good drag time? I couldn't be bothered ha ha
i'll do it.
and i'll try not to blow this one up :)
noel...old man and me are going to keep the greddy mani on for now and then later do a straight manifold swap and do some back to back testing to see dyno and real world difference between greddy and plazmaman on a built motor....how does that sound for ya? We were arguing about it all afternoon....stupid old man, annoys the hell out of me sometimes. Just need some egt sensors in every port or lambda sensors for every port to monitor afrs for every cylinder. Hopefully we will cover most bases, not only will it help with tuning it will help log the results in terms of airflow for each cylinder and whatnot.
Completely random...but i rememeber that thread we were talking about whats better and whats proven and blah blah blah...so here is our chance to actually do that for everyone.
pyro's in which side, intake or exhaust? i remember reading on here somewhere about them and the general consensus was that they'd interfer too much with the air flow
Your man cans are growing bigger by the day. You'll be sitting down to piss next. :laugh:
i thought he already did :)
ahaha..ok..
y do u want to adjust the fuel pressure? if u've got good injectors and a good fuel pump, u shouldnt need to play with the pressure.
doesnt have to be full on racing...even just sprints or the time attack days even top gear.
drag and drift is all over way too quick....wasnt meant to rhyme either.
haha or maybe it was... :D
Edited by r33_racer
nah prolly just a T04Z. My tax return wasnt quite as large as I would have liked
That list on his msn is his list.
that'll still make ~700bhp. well so dan reckons. haha always the way isnt it
ahh i see, we mite see it running in another 5 years :D
well he has to do my engine, check your clearances, and the million other things that he does to help people out.
apparently some tuners prefer being able to dial in more fuel pressure.. and also i wank the wank factor :sorcerer:
just gonna run 740cc nismo direct fit. i forgot what brand pump i got. im ordering the turbo thru aaron 3071R 56 (slide) unless someone recommends otherwise..
maybe ill talk to dan
ahh i see, we mite see it running in another 5 years :)
ahaha coming from u shaney poo.. LOL :D
he's a wanker, get dan to get them for ya
u know its bad when i pay ppl out for build times lol
thaqt would be a good idea, he has the best garrett prices around, also i might be selling my GT2876R .64 T25 flange????
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
