ahaha..ok..
hmm tossing up the idea of buying a a/m FPR or seeing if the standard one works with 740cc.. which sound be flowing 60% at 200 but im going for 240kw. what brand.. had a malpassi before.. not impressed.. perhaps sard..?
perhaps ill try with the standard..any suggestions
*clears throat*
ha ha
Who wants to drive my car to a good drag time? I couldn't be bothered ha ha
i'll do it.
and i'll try not to blow this one up :)
noel...old man and me are going to keep the greddy mani on for now and then later do a straight manifold swap and do some back to back testing to see dyno and real world difference between greddy and plazmaman on a built motor....how does that sound for ya? We were arguing about it all afternoon....stupid old man, annoys the hell out of me sometimes. Just need some egt sensors in every port or lambda sensors for every port to monitor afrs for every cylinder. Hopefully we will cover most bases, not only will it help with tuning it will help log the results in terms of airflow for each cylinder and whatnot.
Completely random...but i rememeber that thread we were talking about whats better and whats proven and blah blah blah...so here is our chance to actually do that for everyone.
pyro's in which side, intake or exhaust? i remember reading on here somewhere about them and the general consensus was that they'd interfer too much with the air flow
Your man cans are growing bigger by the day. You'll be sitting down to piss next. :laugh:
i thought he already did :)
ahaha..ok..
y do u want to adjust the fuel pressure? if u've got good injectors and a good fuel pump, u shouldnt need to play with the pressure.
doesnt have to be full on racing...even just sprints or the time attack days even top gear.
drag and drift is all over way too quick....wasnt meant to rhyme either.
haha or maybe it was... :D
Edited by r33_racer
nah prolly just a T04Z. My tax return wasnt quite as large as I would have liked
That list on his msn is his list.
that'll still make ~700bhp. well so dan reckons. haha always the way isnt it
ahh i see, we mite see it running in another 5 years :D
well he has to do my engine, check your clearances, and the million other things that he does to help people out.
apparently some tuners prefer being able to dial in more fuel pressure.. and also i wank the wank factor :sorcerer:
just gonna run 740cc nismo direct fit. i forgot what brand pump i got. im ordering the turbo thru aaron 3071R 56 (slide) unless someone recommends otherwise..
maybe ill talk to dan
ahh i see, we mite see it running in another 5 years :)
ahaha coming from u shaney poo.. LOL :D
he's a wanker, get dan to get them for ya
u know its bad when i pay ppl out for build times lol
thaqt would be a good idea, he has the best garrett prices around, also i might be selling my GT2876R .64 T25 flange????
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
